130
Removing Padding Between Header Labels
I'm trying to reduce the amount of excess space around my header labels of my XamDataGrid.  I've tried setting the padding value to {0,0,0,0} at the XamTextEditor, HeaderLabelArea, and HeaderPresenter levels with no success.  Has anyone been successful at removing the padding between header labels.
Check out the picture of the grid at the bottom of this link.  The header labels of the XamDataGrid are clearly spaced apart.  I'd like to remove that space/padding entirely.
http://help.infragistics.com/Help/NetAdvantage/WPF/2007.2/CLR3.X/html/xamDataGrid_Changing_the_Default_Column_and_Row_Definitions.html
 Thanks in advance,
Daniel
