495
CardView with column wraparound
Hi, the default cardview is modeled like this:
ColumnName: Attribute
ColumnName: Attribute 2
ColumnName:Attribute 3
ColumnName:Attribute 4
is there any way to specify that I only want two rows in a card, and to wraparound the remaining columns like this:
ColumnName:Attribute   ColumnName: Attribute 3
ColumnName:Attribute 2 ColumnName: Attribute 4
____________
If not, is it possible you could point me to the proper portion of DataPresenterOffice2013 in DefaultStyles\DataPresenter that deals with cardview so that I may make the change myself?  Or is it totally impossible with the current setup?
  • 34510
    Hello Christian,
    You can control the arrangement of the columns by setting the FieldLayoutSettings.AutoArrangeCells property to "Never" and then providing each Field with a Row and Column number.  So in your example, the XAML would look like this:
    <igDP:XamDataCards ...>
        <igDP:XamDataCards.FieldLayoutSettings>
            <igDP:FieldLayoutSettings AutoArrangeCells="Never"/>
        </igDP:XamDataChards.FieldLayoutSettings>
        <igDP:XamDataCards.FieldLayouts>
            <igDP:FieldLayout>
                <igDP:Field Name="Column1" Row="0" Column="0"/>
                <igDP:Field Name="Column2" Row="1" Column="0"/>
                <igDP:Field Name="Column3" Row="0" Column="1"/>
                <igDP:Field Name="Column4" Row="1" Column="1"/>
            </igDP:FieldLayout>
        </igDP:XamDataCards.FieldLayouts>
    </igDP:XamDataCards>
    This would give you the arrangement that you are looking for.  Let me know if you have any questions on this.
