430
Fire SelectedItemsChanged event only when user selects row
In my xamdatagrid, I want to fire  SelectedItemsChanged event only when user selects row with pressing arrows.
But It also fires event when user presses the arrow of a xamcombo in a cell. In the fired event I can control if active cell is null then do nothing.
But in UI when selecting combox it shows user the new selected row is the row of combobox.
I do not want to change selected row when user clicks a cell in another row.
So How can I get this behaviour?
HorizontalAlignment="Stretch" VerticalAlignment="Top" SelectedItemsChanged="calismaProgramGrid_SelectedItemsChanged" >
LabelTextAlignment="Center" AllowLabelVirtualization="True" LabelTextTrimming="None"
FilterOperatorDefaultValue="Contains"/>
HeaderPrefixAreaDisplayMode="FieldChooserButton" DataRecordSizingMode="SizedToContentAndIndividuallySizable"
AllowClipboardOperations="Copy" AutoGenerateFields="False">
Fired event in the below
private void calismaProgramGrid_SelectedItemsChanged(object sender, Infragistics.Windows.DataPresenter.Events.SelectedItemsChangedEventArgs e)
int kId;
XamDataGrid senderGrid = (sender as XamDataGrid);
Cell activeCell = senderGrid.ActiveCell;
if (activeCell == null && senderGrid.ActiveRecord != null)
DataRecord selectedRecord = (DataRecord)this.calismaProgramGrid.ActiveRecord;
if (selectedRecord != null)
CellCollection cells = selectedRecord.Cells;
Cell incTCell = cells.FirstOrDefault(c => c.Field.Name == "KontrolMaddeId");
DenetimCalismaProgrami drv = (DenetimCalismaProgrami)incTCell.Record.DataItem;
if (drv != null)
//bla bla
  • 138253
    Verified Answer
    Thank you for your post. I have been looking into it and I can suggest you add the following check in the XamDataGrid’s SelectedItemsChanged event handler:
    if (e.Type == typeof(DataRecord))
    This way you will be able to determine when the RecordSelector has been clicked. Please let me know if you need further clarification on this matter.
