Using the XamDockManager from 14.201.20142 I get a "Prefix 'igDock' does not map to a namespace." exception thrown whenever I set the theme to "Office2013". Looking through the samples this is supported and works for your example but not my use case, also all other themes I have tried work fine.
I am using Brian Laguna's region adapter in a document content host so views can be injected via regions, see the below code snippet:
<dockManager:XamDockManager> <igWPF:DocumentContentHost> <dockManager:SplitPane > <dockManager:TabGroupPane x:Name="_tabGroupPaneOne" cal:RegionManager.RegionName="{Binding RegionName}" /> </dockManager:SplitPane> </igWPF:DocumentContentHost>
</dockManager:XamDockManager>
Hello Mark,
I downloaded Brian's region adapter sample from his blog and updated the Infragistics assemblies to point to 14.1. I then set the Theme property on the XamDockManager to Office2013 but was not able to reproduce the issue. The sample built and ran as expected. I have attached the updated project.
Is there anything in your project related to the XamDockManager that differs from the one in Brian's sample? Can you modify Brian's sample to reproduce the issue and send it back to me?
Were you able to resolve your issue?
Sincerely,Valerie Developer Support Supervisor - XAMLInfragisticswww.infragistics.com/support
HI
I am facing the similar exception Prefix 'igDock' does not map to a namespace." when using the default theme xaml files.
Any help in this regard will be appreciated.
Mudassir
I have the exact same Problem. I updated all References to IG14.2 and with the Change of selecting the Theme "Office2013" these Errors occur.
xmlns:igDock="clr-namespace:Infragistics.Windows.DockManager;assembly=InfragisticsWPF4.DockManager.v14.2"
<igDock:XamDockManager x:Name="dockManagerMain" InitializePaneContent="DockManagerMain_InitializePaneContent" ActivePaneChanged="DockManagerMain_ActivePaneChanged" Theme="Office2013"></igDock:XamDockManager>
In my cs file i populate the dockmanager this way:
dockManagerDocumentContentHost = new DocumentContentHost(); dockManagerDocumentContentHostSplitPane = new SplitPane(); dockManagerDocumentContentHostTabGroupPane = new TabGroupPane { TabStripPlacement = Dock.Top, AllowDrop = true };
dockManagerDocumentContentHost.Name = "DockManagerDocumentContentHost"; dockManagerDocumentContentHostSplitPane.Name = "DockManagerDocumentContentHostSplitPane"; dockManagerDocumentContentHostTabGroupPane.Name = "DockManagerDocumentContentHostTabGroupPane";
dockManagerMain.Content = dockManagerDocumentContentHost;
dockManagerDocumentContentHost.Panes.Add(dockManagerDocumentContentHostSplitPane); dockManagerDocumentContentHostSplitPane.Panes.Add(dockManagerDocumentContentHostTabGroupPane); <---- Here the Debugger throws that exception.
btw. Same Problem with 14.1
I also tried the following. Perhaps it gives someone an idea. I tried to include the desired xaml-Files as Merged-Dictionaries. So in my app.xaml i reference the File:
<ResourceDictionary Source="Themes/Office2013/DockManagerOffice2013.xaml"></ResourceDictionary>
I got the file from the Installation path. All other needed files are also included in the Project.
DockManagerAero_Brushes.xaml, DockManagerGeneric.xaml and DockManagerOffice2013_Brushes.xaml.
The same error occurs when "DockManagerOffice2013.xaml" is included. When it is included the Design-View appears different for the XamDockManager, so i think it works as intended. If i comment the "DockManagerOffice2013.xaml" so it is not included anymore the error is gone.
All this is without Setting the Theme-Property directly to "Office2013", as my idea was to use the definitions in the XAML-File as default. Sadly it does not work. I´m really sstuck as to where the Problem can be found.
I think i got it fixed.
When using my Approach to include the files manually and not by Setting the Theme-Property to "Office2013" you need to edit the file "DockManagerOffice2013.xaml".
Within this file there are 15 appearances of Binding to the igDock-Namespace which look like "Binding (igDock:".
You need to edit these lines to this "Binding Path=(igDock:".
Just add "Path=", save the file and the error is gone. Why exactly this is i can not tell you.
