This is in continuation from post
http://ko.infragistics.com/community/forums/t/90103.aspx
In which when we use the resource file provided by you.
When using this file the down vertical scroll bar doesn't work, when there are 4-5 items.
it does works when we have 10-15 items.
Please help.
Its urgent.
Rajiv
Hello Rajiv,
I have investigated the sample and I was able to reproduce your issue and as Krasimir said in the other forum thread this behavior is expected, because the DropDown height is calculated based on the Items' count and since an extra item is added, which is not included to the calculations of the height, it is expected that the scrolling is not working correctly all the time. The thing you can try is to set the Height of a Border named "RootPopupElement" to a bigger number. Also you can log a Product Idea for adding "Select All" here:
http://ideas.infragistics.com/
Please let me know if you need further clarifications on this matter.
Hi Stefan,
If you need the license information, then i would be able to provide it, also our company is using your product from last 2 years.
This is an urgent requirement.
Hi Stephen,
The problem is if you scroll down using scroll down button after opening the dropdown, you wont be able to scroll it.
So this is the basic problem which I am facing, Attached is the screen shot marked in red the functionality which is not working.
Please help. And have already asked the D3 team to help but got no reply yet.
rajiv
Thank you for your post. I have been looking into it and I tested the sample Krasimir sent to you and everything seems to work ok on my side. Also, as he said, the thing you want to achieve is not a built in functionality and you can use the sample he sent you as basis for any further implementations. If you need further assistance on this you can contact our consulting team here:
http://d3.infragistics.com/services/
And they will do all the custom functionalities you want.
