120
Grid Expansion
I have two grids both with FlatDataSources. Both will always have the same columns and I need to copy the column expansion states for the first grid to the second grid. So if columns x,y,z are expanded on the first grid, I need to likewise expand them on the second.
I don't want to expand everything, just what is expanded in the first grid. When I found the following post:
http://ko.infragistics.com/community/forums/t/42915.aspx
It seemed to be exactly what I needed. However, using the row header method(as someone stated) doesn't work(since it only gets the first level), and now the filterViewModel approach no longer works since 11.2(as others stated). So how would I go about doing such a behavior?
  • 138253
    Hello Ryan,
  • 138253
    Hello Ryan,
    Thank you for your post. I have been looking into it and I can suggest you use the ExpandToLevelAsync method that the DataSourceBase class exposes. You can see a sample demonstrating how to use this method here:
    http://ko.infragistics.com/samples/silverlight/pivot-grid#/expand-and-collapse-hierarchies
    Let me know if this is the functionality you want to achieve or if you need any further help.
