20
Change background color of xamDataGrid cell based on cell value
My goal is to pass value to every cell in xamdatagrid to Converter. However, I do not know the column names of the DataSource (Datatable) bounded to the grid. XamDataGrid is bounded to DataTable.DefaultView iva view model. I do not know the columns of the datatable.
I have below style defined.
 <igWPF:XamDataGrid.Resources>
                            <Style TargetType="{x:Type igWPF:CellValuePresenter}" x:Key="BackGroundStyle">
                                <Setter Property="Background">
                                    <Setter.Value>
                                        <SolidColorBrush Color="{Binding Path=DataItem, Converter={StaticResource BackGroundConverter}}" />
                                    </Setter.Value>
                                </Setter>
                            </Style>
                        </igWPF:XamDataGrid.Resources>
Code Behind:
  private void xamDailyAudit_FieldLayoutInitialized(object sender, Infragistics.Windows.DataPresenter.Events.FieldLayoutInitializedEventArgs e)
            foreach (var field in e.FieldLayout.Fields)
                field.Settings.CellValuePresenterStyle = xamDailyAudit.Resources["BackGroundStyle"] as Style;
The issue is, my converter is not firing when Path =  DataItem in style. If I add DataItem.columnname in style, then converter fires and cell background changes in XamDataGrid. How can I pass cell value to converter without knowing propertyname or column name.
