Tried to override the edititing settings. But i'm not sure where to put it in the xaml-tree. Here what I tried:
<igXaml:XamGrid.EditingSettings> <igXaml:EditingSettings AllowEditing="Hover"/> </igXaml:XamGrid.EditingSettings>
<igXaml:XamGrid.ColumnLayouts>
<igXaml:ColumnLayout Key="OverrideEditSettings" TargetTypeName="MYCOLUMTYPE">
<igXaml:ColumnLayout.EditingSettings> <igXaml:EditingSettingsOverride IsOnCellActiveEditingEnabled="True" AllowEditing="Cell" IsEnterKeyEditingEnabled="True" IsMouseActionEditingEnabled="SingleClick"/> </igXaml:ColumnLayout.EditingSettings> </igXaml:ColumnLayout> </igXaml:XamGrid.ColumnLayouts> <cgXaml:XamGrid.Columns > <mynamespace:MYCOLUMTYPE IsSortable="False" Key="Combination" />
No change of behavior.
Hello All,
First of all, I apologize for the delay on the update on this development issue.
Development Issue 178207 is currently awaiting the next service release. This issue will be resolved in 13.2, 14.1, and 14.2. The next service release for WPF is estimated to release on October 22, 2014. You can see the full schedule of our upcoming service releases at the link below:
http://ko.infragistics.com/support/service-releases
Sincerely,AndrewDeveloper Support Engineer IInfragistics Inc.www.infragistics.com/support
push, same problem
any development?
I have been able to reproduce this issue in both our 2014.1 and 2013.2 WPF products. You have the override settings in the right place, but keep in mind that the ColumnLayouts in XamGrid are primarily used for hierarchical data. It seems that the override not working only occurs when the EditingSettings in the XamGrid are set to Hover. As a result, I have logged this behavior in our internal tracking system with a Development ID of 178207. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I have made this case viewable to you. It has a case ID of CAS-142248-S0V6J5. I will update you with any new information after the review. You can also continue to send updates to this case at any time.
Please let me know if you need more information.
Sincerely,AndrewDeveloper Support IInfragistics Inc.www.infragistics.com/support
