Hello.
I am using a XamScheduleView.
JournalPresenter is displayed above JournalPresenter.StartLocal is even one minute earlier than ActivityPresenter.StartLocal, but I think how to display below ActivityPresenter always JournalPresenter?
<ig:XamScheduleView.Resources> <Style TargetType="igP:ScheduleActivityPanel"> <Setter Property="Control.Template"> <Setter.Value> <ControlTemplate> <StackPanel /> </ControlTemplate> </Setter.Value> </Setter> </Style> </ig:XamScheduleView.Resources>
I tried to set the style to try, but there is no change in behavior. I look at the code, but it would be useless if you do not change the implementation of ScheduleActivityPanel?
Then, it is although many things were tried. i was disappointment to bind Metadata. (--;Then, it wrote as follow code-behind.
-------------------------------Private Class HeaderInfo Property Border As Border Property CalenderId As String Property IsParent As Boolean Property ResourceId As StringEnd Class
Private _HeaderInfos As New List(Of HeaderInfo)
Private Sub CalendarHeaderVertical_Loaded(sender As Object, e As RoutedEventArgs) Dim header = TryCast(sender, CalendarHeaderVertical) Me.AddHeaderInfo(header)End Sub
Private Sub AddHeaderInfo(header As CalendarHeaderVertical) If header.Calendar Is Nothing Then Return
Dim border = TryCast(Utilities.GetDescendantFromType(header, GetType(Border), True), Border) Dim info = New HeaderInfo() With { .Border = border, .CalenderId = header.Calendar.Id, .IsParent = Not header.Calendar.Id.Contains("J"), .ResourceId = header.Calendar.OwningResourceId }
If _HeaderInfos.Where(Function(i) i.CalenderId = info.CalenderId).Count = 0 Then HeaderInfos.Add(info) End If Me.SetCalendarHeaderBackground()End Sub
Private Sub SetCalendarHeaderBackground() For Each info In _HeaderInfos Dim parent = _HeaderInfos.Where(Function(i) i.ResourceId = info.ResourceId AndAlso i.IsParent) If parent.Count <> 0 Then info.Border.Background = parent.First().Border.Background End If Next End Sub-------------------------------
This is Result View.It became the expected results a little. :)
Thanks.
Thanks again.
Hello Stefan.
Thank you. It's very helpful to your sample.However, it is regrettable your sample, but all Resources will become the same Background. I am looking at now, "generic.shared.xaml". I hope to set for each resource the ComputedBackground・・・I will try so that they refer to the sample of the following thread, and allowed to bind to the template.
http://ko.infragistics.com/community/forums/p/48151/297124.aspx#297124
<Style TargetType="igSchedulePrim:CalendarHeaderVertical"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="igSchedulePrim:CalendarHeaderVertical"> <Border BorderBrush="{TemplateBinding ComputedBorderBrush}" BorderThickness="1" Background="{Binding Metadata[Background]}" Padding="{TemplateBinding Padding}" igPrim:XamlHelper.SnapsToDevicePixels="True"> ・・・・・・</Style>
I have created a sample project for you with the functionality you want. Basically I created a Style for the CalendarHeaderVErtical element and handle its Loaded event. In the handler I change the Background of a border inside its template. Please let me know if this helps you or you have further questions on this matter.
I appreciate your opinion.Provisional correspondence, It corresponded with displayed separately in each of Calendar Appointments and Journals.Divide the Calendar, Background is different, so it is a little troubled.Although I hope can unify the Background for each the Resource.--;
http://cdn-ak.f.st-hatena.com/images/fotolife/h/hilapon/20140828/20140828121449.png
