Hello. This is what I have:
<igWPF:XamDataGrid DataSource="{Binding MainLogDataGrid}" > <igWPF:XamDataGrid.Resources> <ContextMenu x:Key="RecordContextMenu"> <MenuItem Command="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type igWPF:XamDataGrid}}, Path=DataContext.InsertCommand}" Header="Open" /> </ContextMenu> <Style TargetType="{x:Type igWPF:CellValuePresenter}"> <Setter Property="ContextMenu" Value="{DynamicResource RecordContextMenu}"></Setter> </Style> </igWPF:XamDataGrid.Resources> </igWPF:XamDataGrid>
In my main view model class:
public RelayCommand<object> InsertCommand {get; private set;}
public MainViewModel(){InsertCommand = new RelayCommand<object>(OnButtonPressMethod);}
public void OnButtonPressMethod(object menuItem) { var item = menuItem as MenuItem; }
menuItem parameter in OnButtonPressMethod is null when I select whatever is in the context menu. I do have some dummy data in my xamDataGrid. Thanks
thanks.. it works
Hello Rajeev,
You can change the Binding of the CommandParameter like this:
CommandParameter="{Binding RelativeSource={RelativeSource Self},Path=Parent.PlacementTarget.Record.DataItem}"
This way you will get the underlying object as parameter. Please let me know if this helps you or you have further questions on this matter.
I basically want to pass the underlying row details(bond entity) on which user right clicks to perform action using menu item.
If you don't want a reference to the MenuItem in the command, then what you want to do in the command?
I tried this solution and it works. But I have a question. I feel using menuItem(system.windows) reference for typecasting XamDataGrid tag in View model violates the very basic rule of MVVM design. We cannot bring up view reference inside viewmodel . We are inviting the tight coupling again Could you suggest any MVVM way out for this problem. The commands are written in view models.
