1150
EditMode when binding model property to non-grid control
I have a collection of objects bound to a XamDataGrid.
The collection exposes the CurrentItem which is synchronized with the Grids current item.
The item class implements IEditableObject,
and the Undo and Database-Store operations are coded in the interfaces implementation.
One property (containing large text amounts) I need to bind to an external TextBox (not within the grid).
It is bound to MyModel.ItemCollection.CurrentItem.TextProperty
When I edit the item with the grid, the undo and storage operations work all well.
I even can edit the text in the external TextBox, but this will only be saved when I also edit any property on the current item in the grid.
What I want:
As soon I start typing in the TextBox, and the record was not in EditMode before,
the Grid should start into EditMode.
When I simply call Item.BeginEdit the Grid is not informed about this operation at all.
Is there a known solution for this situation?
Thank you.
