I would not like to display a title and subtitle in my XamDataChart. How can I do this (collapse) so not space allocated for these elements?
Thanks in advance
Hello Justin,
Sincerely,
Krasimir, MCPD
Developer Support Supervisor - XAML
www.infragistics.com/support
Thank you for your reply. The xamDataChart should behave the same way in Silverlight as in WPF, since it is a shared control. All shared controls have the same API for both WPF and Silverlight and can be used for cross-platform development. You can see the shared controls under Controls, Components and Frameworks-> Share XAML in our documentation: http://help.infragistics.com/Doc/WPF/current/CLR4.0/?page=Shared_XAML_Controls.html.
If I can assist you with anything else, please do not hesitate to ask.
Hello Krasimir,
Yes I was posted accidentaly to Silverlight it, then I was not sure the answer will be the same for WPF so posted it here. Sorry for the duplicate. The answer there is correct.
Cheers
Justin
Thank you for your post. I have been looking into it and it seems that the question that you are having is the same as the one that you are having at the following forum thread: http://ko.infragistics.com/community/forums/p/92084/455284.aspx#455284 to which I have already replied.
