can any one post the Sample code for the customizable field layout.figure looks like field layout in the link
http://ko.infragistics.com/Control.aspx?panel=overview&id=5971#Gallery
Hello timex1111,
Thank you for your post. I have been looking through it and I suggest you look at the Feature Browser under xamDataGrid / Themes and Custom Styles / Embedded Image Field section where a very similar layout is defined. You only have to change the theme of the XamDataGrid and arrange the Fields using Row, Column, RowSpan, ColumnSpan Properties. Here you can read how to:
http://help.infragistics.com/NetAdvantage/WPF/2011.1/CLR4.0/?page=xamDataGrid_Changing_the_Default_Column_and_Row_Definitions.html
Please note, we are making efforts to ensure all posts are addressed by an Infragistics expert. We believe that the other community members could benefit from this thread as well.
If you have any further questions on this matter do not hesitate to ask.
