195
Field layout
can any one post the Sample code for the customizable field layout.figure looks like field layout in the link
http://ko.infragistics.com/Control.aspx?panel=overview&id=5971#Gallery
  • 25
    Hey timex1111,
    As I went looking for the sample for the screenshot you were mentioning, I ended up finding out that those
    screenshots were from our old 2007.1 samples. And so the sample no longer exists...
    However!!! (this is a good however!)
    I want to help you out so I have re-created the FieldLayouts for that exact sample, to demonstrate how
    it can be done!
    You can also find a great reference using the link below in case whatever I type is confusing or not correct...
    Arranging Fields to Customize your FieldLayout
    The first thing you will need to do is to set AutoArrangeCells="Never" and AutoGenerateFields="False" on your FieldLayoutSettings...
    <igDP:FieldLayoutSettings AutoArrangeCells="Never" AutoGenerateFields="False"
    This next portion of code directly emulates the exact same FieldLayout as seen in that Screenshot,
    the only difference is that I used UnboundFields rather than actual "igDP:Field"s just to see if it worked.
    <igDP:XamDataGrid.FieldLayouts>
    <igDP:FieldLayout>
    <igDP:FieldLayout.Fields>
    <igDP:UnboundField Name="Photo" Row="0" Column="0" RowSpan="3" />
         <igDP:UnboundField Name="Employee Name" Row="0" Column="1"/>
         <igDP:UnboundField Name="Title" Row="1" Column="1"/>
         <igDP:UnboundField Name="Department" Row="2" Column="1"/>
    <igDP:UnboundField Name="Street Address" Row="0" Column="2" ColumnSpan="3" />
         <igDP:UnboundField Name="Apt/Ste Number" Row="1" Column="2" ColumnSpan="3" />
         <igDP:UnboundField Name="City" Row="2" Column="2" />
         <igDP:UnboundField Name="State/Province" Row="2" Column="3" />
         <igDP:UnboundField Name="Postal Code" Row="2" Column="4" />
    igDP:UnboundField Name="E-mail" Row="0" Column="5" />
    <igDP:UnboundField Name="Home Phone" Row="1" Column="5" />
         <igDP:UnboundField Name="Cell Phone" Row="2" Column="5" />
    igDP:FieldLayout>
    </igDP:XamDataGrid.FieldLayouts>
    As you can see each igDP:UnboundField (convert it into an actual igDP:Field) belongs to a specific Row, and Column,
    and can be stretched along the rows or columns using RowSpan="" and ColumnSpan="" to achieve the desired spanning.
    Please let me know if this helps you out!
    Thanks!
    -Tim
