1590
Tooltips on Appointment
Hi, I'm trying to set a tooltip on an Appointment in the XamScheduleView. I have learned that, in order to achieve this, I should define a Style for the ActivityToolTipPresenter, and set the Template property. In this template, I want to bind to some properties of the business object which is the data source for the appointment. I tried to create Appointment object like this:
 Appointment appointment = new Appointment() {  Id = id.ToString(),  ... (more properties) ... ,  DataItem = businessObject };
Then, in the Style I tried to access the business object like this:
<Grid DataContext="{Binding Activity.DataItem.SomeProperty}" />
However, this binding doesn't work. Apparently, the DataItem no longer refers to my BusinessObject, but to itself instead (the Appointment object).
So, how can I achieve the desired effect?
Regards, Stefan
