http://stackoverflow.com/questions/26058905/infragistic-tabcontrol-inherit-template
Thanks for help
Hi Robert,
I believe the explanation you're looking for is here.
http://ko.infragistics.com/community/blogs/andrew_smith/archive/2009/12/09/common-style-issues-when-using-the-theme-property.aspx
And this xaml will accomplish what you are looking for.
<igWindows:XamTabControl Name="xamTabCtrl" DataContext="{Binding }"
ItemsSource="{Binding }"
Theme="Metro" >
<igWindows:XamTabControl.Resources>
<Style TargetType="igWindows:TabItemEx"
BasedOn="{x:Static igThemes:PrimitivesMetro.TabItemEx}">
<Setter Property="Header" Value="{Binding Path=Header}" />
</Style>
</igWindows:XamTabControl.Resources>
<igWindows:XamTabControl.ContentTemplate>
<DataTemplate>
<igDP:XamDataGrid Theme="Metro"
DataSource="{Binding Logins}"/>
</DataTemplate>
</igWindows:XamTabControl.ContentTemplate>
</igWindows:XamTabControl>
Hope this helps you. Please let me know if you have any questions.
I'm looking into your stackoverflow question and I'll try to answer it here shortly.
I appreciate your patience while I look into this further.
