755
OnEditModeEnded validate if row is fullfilled
Hi
I have XamDataGrid and if user leave the cell without fullfilled the whole row, then it should jump to the next empty cell, that the user  have to  fill it with data. until the is fullfiled.
To clarify the scenario, consider the attached picture. I want to force user, that he/she can not leave the row until is fullfile, in my case User and Password field.
Thanks so much.
  • 34690
    Verified Answer
    Hello Jean-Pascal,
    To prevent a user from leaving a record in XamDataGrid until the record has been completely filled with data, and also have the cells jump back to empty editors, I would recommend handling the RecordDeactivating event of the XamDataGrid.
    In the event handler, set a new DataRecord to e.Record to get the record to be deactivated. Then, using a foreach loop, you can loop through each Field F in the DataRecord.FieldLayout.Fields collection. In the loop, call CellValuePresenter.FromRecordAndField(DataRecord, CurrentForeachLoopField) and if the CellValuePresenter’s value = null, call CellValuePresenter1.StartEditMode(), e.Cancel = true, and break.
    I have attached a sample application to demonstrate the above.
    Sincerely,
    Andrew
    Developer Support Engineer I
    Infragistics Inc.
    www.infragistics.com/support
    XDGValidationCase.zip
