SumSummaryOperand defined in a column's columnSettings[i] with IsApplied="True" causes memory leaks in my wpf application. Indeed, the view cannot be disposed by GC. Problem is solved if IsApplied="False" but i need to have IsApplied="True".
So please is there a solution to this issue ?
I use Ants Memory Profiler to tests.
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
https://ko.infragistics.com/my-account/keys-and-downloads/
I have logged this with development under ID: 183059 and I have also created a support ticket on your behalf: CAS-145251-R5M9N1 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Thanks for your answer. I can't send you my all solution but please find in attachment a zip file with sample solution, test results of ANTS Memory Profiler 8 and pdf with explanations.
Hope you could answer as soon as possible ^^
Is it possible for you to send us an isolated sample project where this is reproduced along with the results from the memory profiling and the steps we need to follow in order to replicate this on our side, so we could be able to investigate this further for you?
