Please refer to the attached image. Problem is outlined there.
1) Grid Lines are not aligned
2) Gap between gridlines
3) How to hide the area ?
Hello Rajib,
I am just checking your progress on this issue. Please do not hesitate to let me know if you have any further questions on this matter.
Thank you for your post!
I have been looking into it and have created a small sample application for you. Regarding your third question – I have created two styles. One for the HeaderPrefixArea. By setting the Visibility property of this area to collapsed I am hiding this from the Headers of the XamDataGrid.
The second style is for the RecordSelector. By setting the Visibility property of the element I am hiding it from the records of the XamDataGrid.
Regarding your other questions – I was not able to reproduce the issue you have reported. Would you please modify the attached sample application with the functionality you are using, so it reproduces the issue?
This way I would be able to further investigate this for you.
Thank you for the cooperation. Looking forward to hearing from you.
