Hi Infragistics,
I need to edit the 'there are not any valid treemap nodes' message, so I can localize it to German, for example. I wouldn't mind sorting out the grammar a bit in English too. I had a look in the default template for the control, and a look through the properties, but I can't see where it is set. Any ideas?
Pete
Hello Peter,
Just checking in, did you have any other questions or concerns on this matter?
Sincerely,AndrewDeveloper Support Engineer IInfragistics Inc.www.infragistics.com/support
To localize the “There are not any valid treemap nodes” message, I would recommend doing it through .resx files. I have attached a sample application showing how to use them and register them in your application for your XamTreemap.
For your reference, and if you have the Infragistics samples installed, a common directory to find this .resx file is below:
C:\Users\Public\Documents\Infragistics\2014.2\WPF\Samples\CLR4.0\IGTreemap\Resources\SampleControlStrings
