Hi Team,
I have a requirement where in I need to dynamically load the user controls as Tab pages,I request a sample application for this.
Also , is there a specific styling file for MetroDark theme. If yes,Please share the file as I was not able to find that in our Infragistics package
Using the Selected event throws a design time exception: "Error 2 'Infragistics.Windows.Controls.XamTabControl' does not contain a definition for 'Selected' and no extension method 'Selected' accepting a first argument of type 'Infragistics.Windows.Controls.XamTabControl' could be found (are you missing a using directive or an assembly reference?) "
not sure why though...it's all set from intellisense.
This was a helpful post. In my scenario, the tab control's ItemsSource property is bound to the ViewModel. I can see the TabItemEx objects being created but for the life of me I am not seeing what event to raise to add the user control to the TabItemEx. Any suggestions? Using code behind is fine.
Thank you :)
Hello Raj,
Do you have any other questions on this matter?
Sincerely,Valerie Developer Support Supervisor - XAMLInfragisticswww.infragistics.com/support
As I mentioned previously the second attachment I sent originally contains the MetroDark styles for the XamTabControl.
I am attaching the original sample in VS2010.
Hello Team,
Thank you the solutions which you have sent .
In the MetroDark theme folder I did not find anything related to XamTabControl .
Request you to send the solutions in VS2010 format.Since we don't have higher versions.
Regards
Raj
