I have a problem with multiple XamNumericInputs that trigger validation with each other through a central IDataErrorInfo-ed ViewModel. I'm not sure if I'm doing this correctly, but for most other situations it works, this just seems to happen with the numericinputs (and MaskedTextEditor, for that matter).
What happened is this: I have 2 numbers that need to be validated against each other. One (call it x) must be larger than the other (call that y). Triggering a change in y triggers the OnPropertyChanged event for x manually (this part may not be wisely done) in order to trigger validation. If validation fails, the error for x's editor displays an appropriate tooltip.
In effect, I'm trying to ensure that if I enter a larger value into y, or change x to become smaller than y, x's numericinput should display an error. I've made both inputs' ValidatesOnDataErrors & NotifyOnValidationError properties True, with UpdateSourceTrigger=PropertyChanged.
This happens correctly on the very first time the error triggers (e.g. set y to '10' while x is '0'), but on the very next keystroke (e.g. setting y to '110') the validation disappears. I noticed that the validation highlight appears for an instant, then it disappears again. This happens more often when x is 0 than if it were a larger number, and using Snoop also gave the impression that the error continued to trigger, but then was masked off.
What do I need to do to fix this?
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
https://ko.infragistics.com/my-account/keys-and-downloads/
I have logged this with development under ID: 184675 and I have also created a support ticket on your behalf: CAS-146467-C5B6B4 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Hi there:
Has there been any progress on this? Or have I gone about this functionality wrongly?
Sure, as attached.
There seem to be more problems in this one but the basic issue remains: if I change values on either editors such that 'Smaller' becomes larger than 'Larger', the error shows the first time it triggers, but subsequent editing causes the errors to disappear.
This is difficult because if my user types a series of numbers quickly they wouldn't be able to see exactly why they encountered an error.
Note also that somehow, the 'Smaller cannot be 0' validation does not always trigger, it seems to be that I need to change its value from 0 first.
Thank you for your post. I have been looking into it, but it seems like that I am missing something in your scenario, so could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
