WPF Spread Sheet 14.2
Open dbenfachALL.xlsx, delete [Filial] sheet, it crashes.
dbenfachALL.xlsx (https://www.devexpress.com/Support/Center/Question/Details/Q571743)
It is Excel Engine error, not Spreadsheet control error.
===================================================================================================Infragistics WPF Spreadsheet demo.
<Window xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"; xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"; xmlns:ig="http://schemas.infragistics.com/xaml"; x:Class="WpfApp.MainWindow" Title="MainWindow" Height="350" Width="525"> Load
using System.IO;using System.Windows;using Infragistics.Documents.Excel;
namespace WpfApp{ ///
/// Interaction logic for MainWindow.xaml /// public partial class MainWindow : Window { public MainWindow() { InitializeComponent(); }
private void ButtonBase_OnClick(object sender, RoutedEventArgs e) {
Stream stream = File.Open("mydocument.xlsx", FileMode.OpenOrCreate); Workbook wb = Workbook.Load(stream); if (wb != null) { this.spread.Workbook = wb; } } }}
I found that it is Excel Engine error, not XamSpreadsheet, so, you can delete this thread.
Thank you!
Hello Linden,
I found this post duplicate to this one:
http://ko.infragistics.com/community/forums/p/93168/460724.aspx#460724
which is already discussed.
