555
AllowEdit=false only on single cell
We want to change the AllowEdit-Mode based on the selected value in a XamComboEditor. The AllowEdit should only change in a single cell and not in the whole column. We tried to change the mode in the code-behind. But if we do so, all cells in this column are changed to AllowEdit=false.
I've attached a sample project.
If you change the column "Status" to "ReadOnly" the cell "SecondName" shouldn't be editable and "SerienNummer" should be editable in the same row.
XamDataGridSingleCellReadOnly.zip
