1855
Tooltips on seperate xamdatacharts in a syncgroup
I have three xamdatacharts that are on the same syncchannel.  After updating to 14.2 the tool tips show on all three charts when the mouse is over any of the xamdatacharts in the sync group.. I need the tool tips to show on a per chart basis when the mouse is over the specific chart.
  • 34830
    Hello Pete,
    I followed the steps you suggested and was unable to reproduce the behavior you're describing. I created three XamDataCharts and put them on the same SyncChannel, but the tooltips that were set on the charts did not show on all three at once.
    I have attached the sample project I used to test this.  Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
    If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using.  My test was performed using version 14.2.20142.2024 in Infragistics for WPF 2014 Volume 2.
    If the project does show the product feature working correctly, this indicates a possible problem in the code of your application.  It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
    Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
    Please let me know if I can provide any further assistance.
    Sincerely,
    Andrew
    Developer Support Engineer I
    Infragistics Inc.
    www.infragistics.com/support
    XamDataChartSyncGroupCase.zip
