285
Cannot set both ItemTemplate and DisplayMemberPath on XamComboEditor
Hello Support,
        I'm using Infragistics v14.2 and VS 2013 with Framework 4.0. My requirement is I want a XamComboEditor with Multiple DataTemplates. i.e. My DataItems will be having default template. But my Last DataItem of the combo should be a hyperlink. So I have created ItemTemplateSelector having these both templates but when i tried applying ItemTemplateSelector for drop down items and DisplayMemberPath to actually display selected item in combo editor, it raises run time error as "Cannot set both DisplayMemberPath and ItemTemplate" because i runtime binds data source and sets DisplayMemberPath each time when it focuses.
        To workaround this, i tried removing DisplayMemberPath, it shows items properly in drop down but showing "System.Data.DataRowView" in combo editor after select any item.
        For the second workaround, i also tried above solution and settings SelectedText property to replace the string "System.Data.DataRowView" in "XamComboEditor_TextChanged" but it flickers and user is able to see the manipulation of values. Even i have tried applying style to get the same effect but not succeed. I have tried searching solution on your forums, but didn't find any specific one. So is there any possible workaround for this? I Have attached sample application for your understanding.
XamComboEditor.zip
  • 138253
    Hello Ashish,
    I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
  • 138253
    Hello Ashish,
    Thank you for your post. I have been looking into it and I can suggest you see this forum thread:
    http://ko.infragistics.com/community/forums/t/85483.aspx
    where a similar question is already discussed. Please let me know if you have further questions on this matter.
