315
How to optimize load speed?
My computer Environment:
Core i7 2630QM
DDR3 8GB memory
Windows 8.1 x64
I create a 1048576*20 cells worksheet, and compare it others, memory usage and loading
speed is the following:
                                   [Create Directly]        [Load file]
          Devexpress         Out of memory          1233 MB  83s
           Infragistics         583 MB                     618 MB   130s
MS Excel 2013 x64                                         390 MB   30s
Load speed of different Excel document may be vary, it may be very difficult to optimize all cases.
Thank you.
<Window
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:ig="http://schemas.infragistics.com/xaml" x:Class="InfSpread.MainWindow"
        Title="Infragistics Spreadsheet Test" Height="480" Width="640">
    <Grid>
        <Grid.RowDefinitions>
            <RowDefinition Height="Auto"/>
            <RowDefinition Height="*"/>
        </Grid.RowDefinitions>
        <StackPanel Orientation="Horizontal">
            <Button Margin="5" Content="Create Directly" Click="Create_OnClick"/>
            <Button Margin="5" Content="Create File" Click="CreateFile_OnClick"/>
            <Button Margin="5" Content="Load File" Click="Load_OnClick"/>
        </StackPanel>
        <ig:XamSpreadsheet x:Name="spread" Grid.Row="1"/>
    </Grid>
</Window>
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using Infragistics.Documents.Excel;
using Microsoft.Win32;
namespace InfSpread
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
        private void Create_OnClick(object sender, RoutedEventArgs e)
            var workbook = spread.Workbook;
            workbook.SetCurrentFormat(WorkbookFormat.Excel2007);
            spread.IsUndoEnabled = false;
            FillWorksheet(spread.ActiveWorksheet, 1048576);
            spread.IsUndoEnabled = true;
        private void CreateFile_OnClick(object sender, RoutedEventArgs e)
            var dlg = new SaveFileDialog();
            dlg.DefaultExt = ".xlsx";
            dlg.Filter = "Excel documents (.xlsx)|*.xlsx";
            var result = dlg.ShowDialog();
            if (result == true)
                var file = dlg.FileName;
                // Create a Workbook object
                var workbook = new Workbook();
                var sheet = workbook.Worksheets.Add("Sheet0");
                FillWorksheet(sheet, 1048576);
                using (Stream stream = File.Open(file, FileMode.OpenOrCreate))
                    workbook.Save(stream);
        private void Load_OnClick(object sender, RoutedEventArgs e)
            var dlg = new OpenFileDialog();
            if (result == true)
                var workbook = Workbook.Load(file);
                if (workbook != null)
                    spread.Workbook = workbook;
        private void FillWorksheet(Worksheet sheet, int numberOfRows)
            var sw = new Stopwatch();
            sw.Start();
            for (int index = 0; index < numberOfRows; index++)
                var row = sheet.Rows[index];
                var timeSpan = sw.Elapsed;
                row.SetCellValue(0, string.Format("{0:X8}", index));
                row.SetCellValue(1, timeSpan.Hours * 10000000 + timeSpan.Minutes * 100000 + timeSpan.Seconds * 1000 + timeSpan.Milliseconds);
                row.SetCellValue(2, timeSpan.TotalMilliseconds);
                row.SetCellValue(3, timeSpan.Ticks);
                row.SetCellValue(4, "F");
                row.SetCellValue(5, "400");
                row.SetCellValue(6, "50");
                row.SetCellValue(7, "50, 30, 567");
                row.SetCellValue(8, "2015-12-12");
                row.SetCellValue(9, "Feature Co. Ltd.");
                row.SetCellValue(10, "Star War Plan");
                row.SetCellValue(11, "+1-212-123-1234");
                row.SetCellValue(12, "0123456789-1234567890");
                row.SetCellValue(13, "abcdefgabcdefg hijklnm");
                row.SetCellValue(14, "OPQRST UVWXYZ");
                row.SetCellValue(15, "Description: For free use");
                row.SetCellValue(16, "Indoors use only");
                row.SetCellValue(17, "Maybe you know world trip is a nice thing, o ha ...");
                row.SetCellValue(18, "E-Mail: your.name@outlook.com");
                row.SetCellValue(19, "Say something, I feel lonely, thank you.");
                if (index % 1000 == 0)
                    Console.WriteLine(index);
            sw.Stop();
<Window
        xmlns:dxsps="http://schemas.devexpress.com/winfx/2008/xaml/spreadsheet" x:Class="DevSpread.MainWindow"
        Title="Devexpress Spreadsheet Test" Height="480" Width="640">
    <Grid>
        </StackPanel>
        <dxsps:SpreadsheetControl x:Name="spread" Grid.Row="1"/>
    </Grid>
</Window>
using System;
using System.IO;
using System.Linq;
using System.Text;
using DevExpress.Spreadsheet;
namespace DevSpread
    /// <summary>
    /// </summary>
        public MainWindow()
            spread.BeginUpdate();
            spread.EndUpdate();
            if (result == true)
                spread.EndUpdate();
                spread.SaveDocument(file);
            if (result == true)
                spread.Document.LoadDocument(file);
            sw.Start();
                row[0].Value = string.Format("{0:X8}", index);
                row[1].Value = timeSpan.Hours * 10000000 + timeSpan.Minutes * 100000 + timeSpan.Seconds * 1000 + timeSpan.Milliseconds;
                row[2].Value = timeSpan.TotalMilliseconds;
                row[3].Value = timeSpan.Ticks;
                row[4].Value = "F";
                row[5].Value = "400";
                row[6].Value = "50";
                row[7].Value = "50, 30, 567";
                row[8].Value = "2015-12-12";
                row[9].Value = "Feature Co. Ltd.";
                row[10].Value = "Star War Plan";
                row[11].Value = "+1-212-123-1234";
                row[12].Value = "0123456789-1234567890";
                row[13].Value = "abcdefgabcdefg hijklnm";
                row[14].Value = "OPQRST UVWXYZ";
                row[15].Value = "Description: For free use";
                row[16].Value = "Indoors use only";
                row[17].Value = "Maybe you know world trip is a nice thing, o ha ...";
                row[18].Value = "E-Mail: your.name@outlook.com";
                row[19].Value = "Say something, I feel lonely, thank you.";
            spread.EndUpdate();
            sw.Stop();
  • 35319
    Hello Linden,
  • 35319
    Hi Linden,
    Thank you for your post. I have been looking into it and I am not sure whether you are reporting loading issue in our Infragistics Excel Engine or in our  XamSpreadsheet control.
