Changing the background color to something other than white leaves a small white dot at the bottom of the control. Is there anyway to remove this dot or change it to a similar color?
Aaron
Hello Aaron,
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account\My Keys and Downloads.
We have further investigated this and it seems to be an issue with the XamRichTextEditor. I have logged this behavior with our developers in our tracking system, with an issue ID of 186113. I have also created a support ticket on your behalf with number 4 in order to link the CAS-147749-B6K2T5 development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Sincerely,
Krasimir, MCPD
Developer Support Supervisor - XAML
www.infragistics.com/support
Thank you for your post. I have been looking into the appearance that you have described and the white spot is a Rectangle that is inside the template of the RichDocumentViewPresenter. You can remove it by setting the margin of that rectangle in the Loaded event of the XamRichTextEditor. I have created a sample application for you, that shows how you can implement this approach.
Please let me know if I can assist you with anything else.
