2815
Creating datatemplate programmatically for xamDataTree causing {"A NodeLayout with this key is already in this collection."} exception
I have created a DataTemplate as part of a resource of a user control with the following XAML:
<UserControl x:Class="XamDataTreeApp.SystemSettingsView"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml">
<UserControl.Resources>
<ResourceDictionary>
<DataTemplate x:Key="AppSettingsProviderDataTemplate">
<StackPanel Orientation="Horizontal">
<ContentPresenter Grid.Column="1" Content="{Binding Icon}" Margin="4,1,0,1" />
<TextBlock Grid.Column="2" Margin="4,1,0,1" FontWeight="Normal" Text="{Binding Alias, Mode=OneWay}" VerticalAlignment="Center" />
</StackPanel>
</DataTemplate>
</ResourceDictionary>
</UserControl.Resources><Border><ContentPresenter TreeViewContainer/></Border></UserControl>
and code behind.
public partial class SystemSettingsView
public SystemSettingsView(ITreeViewFactory treeViewFactory)
InitializeComponent();
Loaded += (sender, args) =>
if (TreeView == null)
var treeCreationCtx = new TreeViewCreationContext
Name = "SystemSettingsView",
DataContext = DataContext,
ItemSourceBinding = new Binding("SettingProviders"),
ItemDataTemplate = (DataTemplate)Resources["AppSettingsProviderDataTemplate"],
OnSelectionChanged = (selectedItem) =>
var systemSettingsViewModel = DataContext as SystemSettingsViewModel;
if (systemSettingsViewModel != null)
systemSettingsViewModel.SelectedSettingsProvider = (IAppSettingsProvider) selectedItem;
TreeView = treeViewFactory.GetTreeView(treeCreationCtx);
public FrameworkElement TreeView
get { return TreeViewContainer.Child as FrameworkElement; }
set
TreeViewContainer.Child = value;
When I attempt to programmatically create an instance of xamDataTree that users this template with the following constructs:
public FrameworkElement GetTreeView(TreeViewCreationContext creationContext)
if (creationContext == null)
throw new ArgumentNullException("creationContext");
if (creationContext.IsInvalid())
throw new InvalidDataException("creation context is not valid");
var tree = new XamDataTree()
Name = creationContext.Name,
NodeLineVisibility = Visibility.Visible,
DataContext = creationContext.DataContext
tree.SetBinding(XamDataTree.ItemsSourceProperty, creationContext.ItemSourceBinding);
if (creationContext.SelectedItemBinding != null)
tree.SetBinding(XamDataTree.SelectedDataItemsProperty, creationContext.SelectedItemBinding);
if (creationContext.ItemDataTemplate != null)
var nodeLayout = new NodeLayout();
nodeLayout.ItemTemplate = creationContext.ItemDataTemplate;
tree.GlobalNodeLayouts.Add(nodeLayout);
if (creationContext.OnSelectionChanged != null)
tree.SelectedNodesCollectionChanged += (sender, args) => creationContext.OnSelectionChanged.Invoke(tree.SelectedDataItems.First());
return tree;
public class TreeViewCreationContext
public string Name { get; set; }
public object DataContext { get; set; }
public Binding ItemSourceBinding { get; set; }
public DataTemplate ItemDataTemplate { get; set; }
public Action<object> OnSelectionChanged { get; set; }
public Binding SelectedItemBinding { get; set; }
public bool IsValid()
return !IsInvalid();
public bool IsInvalid()
if (DataContext == null)
return true;
if (ItemSourceBinding == null)
return true;
if (ItemDataTemplate == null)
return true;
return false;
I get the following exception: "A NodeLayout with this key is already in this collection."
If I do the same thing using WPF native treeview as follows:
var tv = new TreeView { Name = creationContext.Name, DataContext = creationContext.DataContext };
tv.SetBinding(ItemsControl.ItemsSourceProperty, creationContext.ItemSourceBinding);
tv.ItemTemplate = creationContext.ItemDataTemplate;
tv.SetBinding(BindableSelectedItemBehavior.SelectedItemProperty, creationContext.SelectedItemBinding);
tv.SelectedItemChanged += (sender, args) => creationContext.OnSelectionChanged.Invoke(tv.SelectedItem);
var behaviors = Interaction.GetBehaviors(tv);
behaviors.Add(new BindableSelectedItemBehavior());
return tv;
I do not have this problem.
Any tips?
