255
xamCurrencyInput SelectAll Behavior is Broken
I'm using version 13.2.20132.2284 and my code calls xamCurrencyInput.SelectAll() method within the GotFocus event handler.
However, not all characters get selected when I use the TAB key to navigate into the control (see attached image). It works OK when I use SHIFT-TAB to navigate into it (tabbing backward from control to this control)
Interestingly enough that it works OK for the xamDateTiimeInput. It used to be a problem before (see this post). The workaround offered in that post does not work for this issue.
After running this code:
maskedInput.SelectionLength = maskedInput.TextLength
The SelectionLength value is smaller than TextLength.
