995
databinding dataset to XamDataTree
I am trying to bind an sqlce data set to a XamDataTree based on WPF > Style > Theming example provided in the Samples Browser for infragistics 12.2
I would like the parent node to the contain 2 columns as in the example.  The fields used would be Assessment Date and AssessedBy.
The child node would be DatePrescribed.
How do i bind my datasource (shown below) to the xamdatatree as i am struggling with the examples i have found in the forums.  I am using VB.
Public Shared Function GetClientAssProgHistory(ByVal clientid As Integer) As DataSet
' Initialize DataSet and name it
Dim myDataSet As New DataSet("myDataSet")
'create the sql connection to the database
Dim con As SqlCeConnection = New SqlCeConnection(My.Settings.myCompactDBConnectionString1)
'define the query
Dim sqlquery As String
sqlquery = "select AssessmentDate, AssessedBy, PresentProblems, DatePrescribed" & _
" from DClientAssessment ca left outer join DClientProgrammeHistory ph on ca.DClientAssessmentID = ph.DClientAssessmentID" & _
" left outer join dclientmaster c on ca.clientid = c.clientid " & _
" where c.clientid = '" & clientid & "'" & _
" order by AssessmentDate desc, DatePrescribed desc"
'define the sql commend
Dim cmd As New SqlCeCommand(sqlquery, con)
' Initialize the SqlDataAdapter
Dim daclienthistory As New SqlCeDataAdapter(cmd)
Try
' Fill the DataSet
daclienthistory.Fill(myDataSet, "ClientHistory")
Catch ex As SqlCeException
' Catch and display any exceptions that may occur
MessageBox.Show(ex.Message.ToString())
End Try
Return myDataSet
End Function
  • 138253
  • 138253
    Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically the Key of the child layout should match the Relation name of the DataSet and the TargetTypeName of both NodeLayouts should be DataRowView. Please let me know if you have further questions on this matter.
    XamDataTreeDataSetBinding.zip
