Hello
We are using Ig 12.2.20122.2292
There is a problem with conditional formatting.
I've attached sample application.
It's a simple grid with numbers. Numbers are colored.
When you scroll down, you can easily see that for short period of time the values are black.
Finally when you drop scroll, values are colored.
The worst case is when you scroll 1 page. Then, the values are black until you hover / click cells.
In 12.x and 13.x versions it behavies like I described.
This seems to be fixed in 14.2 version.
Is there a chance to have that fixed in 12.2 or do we have to switch to 14.2?
(We don't want to switch to 14.2 as we have end of development for a project, and a patchfix for 12.2 would be better for us).
Or even a workaround would be great.
Thx in advance!
Thank you for your feedback Lukas. I am glad that this information was helpful.
Thank you.
I think the reply was clear to me .
Hello Lukas,
I am just checking if my last reply was helpful for you.
If you require any further assistance, please do not hesitate to ask.
Hello Lukas and thank you for posting!
It seems that the fix for this issue was released after the last service release date for version 12.2 had been expired. Currently we do not provide any release versions prior to 13.2. You may have a look in our Product Lifecycle page for additional details: http://ko.infragistics.com/support/product-lifecycle. The page is updated according to our schedule. I have tried to run the project you shared using version 12.2.20122.2292 and on my side an InvalidOperationException is thrown. Could you please double check the attached sample? A fix for this issue seems to be available with the latest build for 13.2 – 2284. Have you tested the scenario with it?
