2325
Dynamically generating field layouts
I am using 14.2 for my wpf project. I want to have a window with a xamDataGrid in it and have that window reusable.  I have 11 models.  The window will show a given models task(which is data that needs maintenance).  A model may have between 2 to 7 different data sources(derived from Linq to EntityFramework).  The user will choose from a dropdown which table/task to edit in the grid.
Consistent behavior should be as follows:
  1. being allowed to identify those columns that are allowed edit
  2. the cell background of the editable cell should be a different color from the readonly cell.
  3. possibly, allow column hiding (collapsing).
So I understand I can create field layouts in XAML, however I am wondering if I can do the same thing in the code behind and have the behavior that is required?
Another question is; how do I toggle between the different layouts when I change the data source?
