Hello, I'm having problem with CategoryToolTipLayer while trying to display it for different series. All series are using the same CategoryXAxis and different/same NumericYAxis. The problem appears when series (ItemSource) have different range (they use same CategoryXAxis and NumericYAxis). Here:
If I do mouse over from the left side, tooltip shows both values (as they exist). If I will go to the right side (mouse over) then I get 1 value (2nd should not be visible at all) and tooltip shows in the middle between left corner (X=0) and X mouse position. Any suggestions?
Thanks in advance!
Nikolay
Well, I found my mistake. Thanks for help! :)
Hello Nikolay,
Just checking in, did you have any other questions or concerns on this matter?
Sincerely,AndrewDeveloper Support Engineer IInfragistics Inc.www.infragistics.com/support
Thank you for the screenshot attachments.
From your original post, I am not entirely sure of the functionality you are trying to achieve. I see in the screenshots that you provided that when your mouse is over an area where the shorter series does not stretch to, the tooltip does not stay aligned with the mouse. From your original description, I understand that you want the tooltip to either stay aligned with the mouse or to be somewhere between the bottom-left corner and the mouse position. Could you please elaborate a little further on the functionality that you are trying to achieve with the CategoryTooltipLayer?
Here :)
Thank you for your post!
It appears that the screenshots you have attempted to attach did not attach correctly. Would it be possible for you to attach these screenshots in a .zip file so that I can see them?
