Hi.
Is there some way to select node of XamOrgChart by right mouse click? Or at least get node under mouse cursor?
Thanks for reply.
Thank you, I know how to handle events in MVVM, but I couldn't get it to work. Just a bad day I think, because I solve in a instant today. Thank you for quick replies and solution.
Hello Lukas,
Here you can see how to handle events in MVVM way:
http://social.technet.microsoft.com/wiki/contents/articles/18199.event-handling-in-an-mvvm-wpf-application.aspx
Thank, it is working. Just out of curiosity, is there way to get it work using MVVM pattern? I mean without code behind.
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I created a Style for the OrgChartNodeControl and added EventSetter for the PreviewMouseRightButtonDown event and in the handler I set the Node’s IsSelected Property to true. Please let me know if this helps you or you have further questions on this matter.
