535
Selection over ValuePath on an UnboundFiled-XamComboEditor
Hi there,
I’m having trouble to use a XamComboEditor in a XamDataGrid UnboundField.
I have a ViewModel which saves my possible ComboBox-selection in a unit-ObservableCollection, this selectable object has a Name, a UnitSymbol and a UnitId property.
On the other hand my XamDataGrid gets a collection of Parameters, where every object has an own instance of a unit. So for this reason I can’t use SelectedItem to preselect its own unit from my unit-Collection, because the object in the collection and in the Parameter is different, even with the same metadata. (btw. if every parameter-object gets his unit from my unit-collection everything is just fine, when I use SelectedItem)
So my problem is that I want to show my Parameter-unit with its UnitSymbol but I have to select it by its UnitId, to match it with my unit-collection.
If I try to use the ValuePath-Property I only get the object-name displayed.
Also every Parameter has some Child-Parameter with the same type.
BR
Andreas
WpfApplication1.zip
