290
Binding on AxisLabelSettings.Visibility not wirking for CategoryDateTimeXAxis
For CategoryXAxis everything works OK:
<ig:CategoryXAxis x:Name="XAxis" ItemsSource="{Binding Data}" DateTimeMemberPath="X" Label="{}{X}">
    <ig:CategoryXAxis.LabelSettings>
        <ig:AxisLabelSettings>
            <ig:AxisLabelSettings.Visibility>
                <Binding Path="IsAxis1Visible" Mode="OneWay">
                    <Binding.Converter>
                        <common:AxisVisibilityConverter/>
                    </Binding.Converter>
                </Binding>
            </ig:AxisLabelSettings.Visibility>
        </ig:AxisLabelSettings>
    </ig:CategoryXAxis.LabelSettings>
</ig:CategoryXAxis>
but not for:
<ig:CategoryDateTimeXAxis x:Name="XAxis" ItemsSource="{Binding Data}" DateTimeMemberPath="X" Label="{}{X}">
    <ig:CategoryDateTimeXAxis.LabelSettings>
                    <Binding.Converter>
                </Binding>
    </ig:CategoryDateTimeXAxis.LabelSettings>
</ig:CategoryDateTimeXAxis>
When I set it explicitly it works too:
                <Visibility>Collapsed</Visibility>
Converter:
    [ValueConversion(typeof(bool), typeof(Visibility))]
    public class AxisVisibilityConverter : IValueConverter
        public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
            try
                var active = (bool)value;
                if (active)
                    return Visibility.Visible;
                return Visibility.Collapsed;
            catch
        public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
            try
                var visibility = (Visibility)value;
                switch (visibility)
                    case Visibility.Visible:
                        return true;
                    default:
                        return false;
            catch
                return false;
