Is it possible to create a vertical menu with a slide out and lock functionality. I.e like a dock panel to the left that can be pinned however is a menu and allows the pin button to be in a custom place. I can do most of this the DockManager except that I need the whole side to cause the "flyout" effect not just the header and that it should "flyin" as soon as the mouse is not over it, also not sure that the pin button can be moved?
Hello Hagashen,
I am glad that I was able to help.
Again thanks for the speedy reply and the great work. This is exactly what I am looking for. Thanks again it is much appreciated.
I have modified the sample I sent you before, so now it has the functionality you want. Please let me know if this helps you or you have further questions on this matter. Looking forward for your reply.
I just noticed that in your example there is a small gap at the top of the pane. Is there a way to get rid of this? I managed to get rid of the bottom one by changing the HeightConverter to subtract 15 instead of the 18 you had. Also is there a way to style the header so that it does not appear?
Thank you for your feedback. I am glad that my solution helps you and I believe that other community members may benefit from this as well.
Thanks again.
