Is there a save method or functionality built into the diagram?
Also, is there a way to export the diagram as an image or pdf file?
Hello BeethovenCS,
I apologize for the delay in my response.
It appears that you have since created a support case for this issue (CAS-178061-R4T8S7), and this issue was found to be a bug in the XamDiagram control. It appears that another support agent, Noriko has since provided you with a private build that will hopefully fix this issue that you are referring to.
To any others who may see this post, this persistence issue has been fixed internally in the 2016.1 and 2016.2 version of the XamDiagram. The fix is not yet public, but should become public in the next service release for WPF. An estimate for when the next service release should come out can be found here: http://ko.infragistics.com/support/service-releases.
Sincerely,AndrewAssociate Developer
Hi Andrew,
Thanks for the printing sample. It was a great help.
Are there any samples for using the persistence framework with xamDiagram? I built one with the 14.1 CTP which persisted as i expected but then i could not reload shapes when i converted the same code using the 16.1 "released" versions - i just received a blank diagram
Hello Raghu,
I have created a sample project to demonstrate both the Tree Layout and the export to image of content that is off-screen. To export the off-screen content to an Image, I would recommend calling Measure and Arrange on the containing element of the XamDiagram as well as the diagram itself. In the case of my project, that containing element is a Grid.
Then, using a new RenderTargetBitmap object, I render the containing element and then using a PngBitmapEncoder, I export the grid to a .png file. Then, I set the LayoutRoot height and width back to what it was before so that no visual changes are made to the user.
The sample project is attached.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
Would it be possible for you to provide some more detail regarding your XamDiagram? The tree layout should not overlap any nodes in the XamDiagram. Also, could you please provide the specific version of Infragistics for WPF 14.2 that you are using?
In the meantime, I will be doing some research to see if there is a way to export the XamDiagram to an Image without having to zoom out and then export.
Hi Andrew, I tried the TreeDiagramLayout and nodes are still being overlapped
