1235
XamComboEditor sort by DisplayMember
i got a XamComboEditor inside a XamDataGrid with a LookUpList Int / String. (It works fine)
If i sort after this field, its randomly before or after the DisplayMember is subsituted by the text. (The LookUpList ItemSource is set only once at start, so its always there already.) I saw this in GroupByRecord.Description, while override the GroupByComparer, trying to workaround this..
Shouldnt it always be sorted after subsituted by text. And if not, is there an event i can listen for after loaded a new ItemSource to the Grid? (Binding)
xaml:
c#:
_grid.FieldLayouts[0].SortedFields.Clear();
_grid.FieldLayouts[0].SortedFields.Add(new FieldSortDescription("NrID", System.ComponentModel.ListSortDirection.Ascending, true));
_grid.Records.RefreshSort();
Greetings
KiTs
