355
Excel Workbook load performance issue
 Hi Support,
We are using WPF Infragistics 2014.2 and facing performance issue with Infragistics Excel engine to load the Excel (.xls/.xlsx) file. The “Workbook.Load” method takes lot of time to load the file and resulting in either freezing the application or raising “OutOfMemoryException”. The excel file we are trying to load has 9 billion rows and 15 columns (no.of rows and columns may vary on data). We also tried loading this file on the machine with higher configuration (8 GB RAM), however still loading the workbook takes time and result in “OutOfMemoryException”.
  Following is the code snippet we have used to load the workbook and read its sheet names.
 Object _workBookOrCSV = Infragistics.Documents.Excel.Workbook.Load(workbookPath);
 //cboWorksheet is ComboBox here
for (int i = 0; i < ((Workbook)_workBookOrCSV).Worksheets.Count; i++)
    cboWorksheet.Items.Add(((Workbook)_workBookOrCSV).Worksheets[i].Name);
 Can you please let us know whether Infragistics Excel engine has any limit on file size to be loaded in an object at a time and also any other way to load the excel file?
  • 138253
    I am just checking if you still require any assistance or clarification on the matter.
  • 138253
    Hello Rheal,
    Thank you for your post. I have been looking into it and I can say that there is no limit on file size, but the data you are trying to load I very big and since many objects are created for a particular row it is expected that at some time the memory ends. As for the loading, I can say that this is time and resource consuming operation and it cannot be done immediately. I assume that if you open this file with excel it takes some time to load, too. The thing you can do is log a product idea for adding an option for Load on demand. This way you will be able to load only part of the whole file. You can log the idea here:
    http://ideas.infragistics.com/
    Please let me know if you have further questions on this matter.
