My english is not good
Add only a new record ,chart Do not display
I hope Add only a new record display on chart
I upload a sample, you help me to see where i was wrong.
thanks
When only one point is contained in the series, the actual minimum and actual maximum values of the CategoryDateTimeXAxis are the same therefore there is nothing displayed, when you add the second point, provided it is on a new date, then there will be a range for the axis to display and the points will be shown. You can prevent this by setting a minimum and maximum value on the axis.
Sincerely,
Valerie
Software Developer
www.infragistics.com/support
Hello ,
When you add record in the XamDataGrid Only,There is only one,points in the XamDataChart are not display
Hello Guo Yafei,
Thank you for your post. I have been looking into the sample that you have attached and it seems to be behaving as expected. When you add records in the XamDataGrid, points in the XamDataChart are also added. Would you please provide me with more details on the exact issue that you are having?
Krasimir, MCPD
Developer Support Supervisor - XAML
