I am running into an issue similar to:
http://ko.infragistics.com/community/forums/t/91868.aspx
I have a xamGeographicMap WPF window hosted in a WinForm-interop situation where the XamGeoMap window is started in a separate thread from the main WinForm UI menu. Opening the map window once works without issue, but opening a second instance causes the application to crash with the error shown below. I have attached a sample application, just push "button1" two times to see the crash (a new WPF window/xamGeoMap in a separate thread is created and opened each time the button is pressed). If I just open the WPF window in the main WinForms thread, it works as expected.
System.Windows.Markup.XamlParseException occurred HResult=-2146233087 Message='The invocation of the constructor on type 'Infragistics.Controls.Maps.XamGeographicMap' that matches the specified binding constraints threw an exception.' Line number '8' and line position '10'. Source=PresentationFramework LineNumber=8 LinePosition=10 StackTrace: at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri) at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri) at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream) at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator) at GeoMapWinFormHost.WPFWindow.InitializeComponent() in c:\Projects\Sandbox\GeoMapWinFormHost\GeoMapWinFormHost\GeoMapWinFormHost\WPFWindow.xaml:line 1 at GeoMapWinFormHost.WPFWindow..ctor() in c:\Projects\Sandbox\GeoMapWinFormHost\GeoMapWinFormHost\GeoMapWinFormHost\WPFWindow.xaml.cs:line 12 InnerException: System.InvalidOperationException HResult=-2146233079 Message=Cannot access Freezable 'System.Windows.Media.ImageBrush' across threads because it cannot be frozen. Source=PresentationFramework StackTrace: at System.Windows.StyleHelper.ProcessInstanceValuesHelper(ItemStructList`1& valueLookupList, DependencyObject target, Int32 childIndex, HybridDictionary instanceValues, Boolean apply) at System.Windows.StyleHelper.ProcessInstanceValuesForChild(DependencyObject container, DependencyObject child, Int32 childIndex, HybridDictionary instanceValues, Boolean apply, FrugalStructList`1& childRecordFromChildIndex) at System.Windows.StyleHelper.CreateInstanceData(UncommonField`1 dataField, DependencyObject container, FrameworkElement fe, FrameworkContentElement fce, Style newStyle, FrameworkTemplate newFrameworkTemplate) at System.Windows.StyleHelper.UpdateInstanceData(UncommonField`1 dataField, FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, FrameworkTemplate oldFrameworkTemplate, FrameworkTemplate newFrameworkTemplate, InternalFlags hasGeneratedSubTreeFlag) at System.Windows.StyleHelper.DoStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle) at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache) at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.ScheduleTransfer(Boolean isASubPropertyChange) at MS.Internal.Data.ClrBindingWorker.NewValueAvailable(Boolean dependencySourcesChanged, Boolean initialValue, Boolean isASubPropertyChange) at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange) at MS.Internal.Data.PropertyPathWorker.OnDependencyPropertyChanged(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange) at MS.Internal.Data.ClrBindingWorker.OnSourceInvalidation(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.StyleHelper.ApplyStyleOrTemplateValue(FrameworkObject fo, DependencyProperty dp) at System.Windows.StyleHelper.InvalidateContainerDependents(DependencyObject container, FrugalStructList`1& exclusionContainerDependents, FrugalStructList`1& oldContainerDependents, FrugalStructList`1& newContainerDependents) at System.Windows.StyleHelper.DoStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle) at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache) at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.ScheduleTransfer(Boolean isASubPropertyChange) at MS.Internal.Data.ClrBindingWorker.NewValueAvailable(Boolean dependencySourcesChanged, Boolean initialValue, Boolean isASubPropertyChange) at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange) at MS.Internal.Data.PropertyPathWorker.OnDependencyPropertyChanged(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange) at MS.Internal.Data.ClrBindingWorker.OnSourceInvalidation(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.StyleHelper.ApplyStyleOrTemplateValue(FrameworkObject fo, DependencyProperty dp) at System.Windows.StyleHelper.InvalidateContainerDependents(DependencyObject container, FrugalStructList`1& exclusionContainerDependents, FrugalStructList`1& oldContainerDependents, FrugalStructList`1& newContainerDependents) at System.Windows.StyleHelper.DoThemeStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldThemeStyle, Style newThemeStyle, Style style) at System.Windows.StyleHelper.UpdateThemeStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldThemeStyle, Style newThemeStyle, Style& themeStyleCache) at System.Windows.FrameworkElement.OnThemeStyleChanged(DependencyObject d, Object oldValue, Object newValue) at System.Windows.StyleHelper.GetThemeStyle(FrameworkElement fe, FrameworkContentElement fce) at System.Windows.FrameworkElement.UpdateThemeStyleProperty() at System.Windows.FrameworkElement.OnThemeStyleKeyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.FrameworkElement.set_DefaultStyleKey(Object value) at Infragistics.Controls.Maps.XamGeographicMap..ctor() at System.Xaml.Schema.XamlTypeInvoker.DefaultCtorXamlActivator.InvokeDelegate(Action`1 action, Object argument) at System.Xaml.Schema.XamlTypeInvoker.DefaultCtorXamlActivator.CallCtorDelegate(XamlTypeInvoker type) at System.Xaml.Schema.XamlTypeInvoker.DefaultCtorXamlActivator.CreateInstance(XamlTypeInvoker type) at System.Xaml.Schema.XamlTypeInvoker.CreateInstance(Object[] arguments) at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstanceWithCtor(XamlType xamlType, Object[] args) at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstance(XamlType xamlType, Object[] args) InnerException:
This is working in v15.1.20151.2055
Thanks!
Hello Gary,
I believe this is a development issue, and I have asked our engineering staff to examine this issue further. To ensure that this issue will receive attention, I have logged this behavior in our internal tracking system with a development ID of 189398.
I have created a private case for you so that you can track the progress of this development issue. The case number is CAS-151411-Y7G5M4. You can access it here: https://ko.infragistics.com/my-account/support-activity.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
Thank you for your post.
I have taken a look at the sample project you have sent, and I have reproduced this exception you are seeing. After looking at the inner exception in the exception details, it appears that this is happening because of the inability to access Freezable System.Windows.Media.ImageBrush across threads because it cannot be frozen.
This may be an issue for our development team, but I am not entirely sure yet. I will continue to investigate this, and I will keep you updated on this matter.
