I need to create a grd with a master-detail expandable row, so that when the row is selected it would dicplay child records of this row. The solution provided in the samples using
ExpandableFieldRecordExpansionMode does not fit in the arhcitecture of the existing solution and also it is not quite clear from the sample how I can customize the fields in the master/detail rows.
Can anyone suggest alternative solution suitable for MVVM design pattern?
Thanks.
Hi Ilya,
Thank you for your reply. I am glad that you have managed to resolve your issue.
Let me know, if you need any further assistance on this matter.
The problem was solved by applying FieldSettings to each FieldLayout.
additional question:
I set up the filtering in the parent grid. By default the same layout applie to a child record, so that child grid also has filtering options, which is not necessary. How to disable filtering in the child grids and still have them in the parent grid.
It did work after a minor fix (actually adding members to child collection, which was not performed in the original code due to a bug)
your example does not work (when I click on a + icon it just disappears without displaying child record). (See attached file)
Please advise.
