Is it at all possible to change the template for how nodes are displayed in a XamDataTree? See the attached image for example. Here, I want two levels of nodes. For the child nodes, I want them displayed as a list with three columns and however many rows needed. In the attached image, there would be 9 sub-nodes below the main node Alarm. Any suggestions how to accomplish something like this?
Arthur
Thank you for your feedback Arthur and please feel free to write in the forums or to create a support ticket if you have any questions or concerns.
Thank you for the prompt response. I think I will go a different way with the UI design.
Hello Arthur,
XamDataTree is designed to display one node at a specific level and arranging the nodes in multiple columns is not supported. You can try to modify the default XamDataTreeNodeControl template so that on node consists of three items separated by white space. This will probably require the changes of the data source as well since the node should receive the data from to more items. You can find the default style in the generic.xaml file in C:\Program Files (x86)\Infragistics\2014.2\WPF\DefaultStyles folder if you would like to try this approach.You can also suggest a new product idea this feature to be implemented at http://ideas.infragistics.com. Additional details on the process could be found below.
Steps to create your idea: 1. Log into the Infragistics Product Ideas site at http://ideas.infragistics.com (creating a new login if needed).2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The benefits of submitting the product idea yourself include:- Direct communication with our product management team regarding your product idea.- Notifications whenever new information regarding your idea becomes available.
Additional benefits of the Product Idea system include:
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.- Allow you to shape the future of our products by requesting new controls and products altogether.- You and other developers can discuss existing product ideas with members of our Product Management team.
The product ideas site allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
