Hi, As I say in the subject I want to add to the QuickAccessToolbar An OpenSomething and a CloseSomething that is made as follows:
<igr:ApplicationMenu2010Item KeyTip="O" Image="..." Command="{x:Static lcmd:MyCommand.Open}"> <igr:ApplicationMenu2010Item.Header> <TextBlock Margin="5,0,0,0" Text="Open" /> </igr:ApplicationMenu2010Item.Header> </igr:ApplicationMenu2010Item>
Usually to add a ribbon tool to the QUickaccess toolbar you have to write this
<igr:QatPlaceholderTool TargetId="openTool"/>
The Problem is that the ID or Id attribute is not applicable to the ApplicationMenu2010Item so I wanted to understand what should be modified to be able to use the Application menu Item in the QUickAccess toolbar.
Thank you in advance
Thank You this solves my problem
ApplicationMenu2010Item is only allowed/used within the ApplicationMenu2010. If you want to put a tool into the QAT that isn't displayed within a RibbonGroup, MenuTool, etc. then you can define the tool within the ToolsNotInRibbon and then you can define the QatPlaceholderTool as you would for other tools.
e.g.
<igRibbon:XamRibbon.ToolsNotInRibbon> <igRibbon:ButtonTool Id="openTool" Command="ApplicationCommands.Copy" Caption="Open" SmallImage="Images\16x16.png" /></igRibbon:XamRibbon.ToolsNotInRibbon>
