hi,
I did some searching but couldn't find anything that would suit my needs.
What I am looking for is to have summary values displayed in the GroupRow, aligned with its column header as seen in the screenshot below.
I am on version 14.2.
Thank you
Srikar
Hello Srikar,
I am glad that you were able to resolve this issue you were having.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
I found out how to correct this issue.
The itemsControl within SummaryResultsPresenter had Background set to the default theme values. I had to set it to the templatedParent instead.
<Style TargetType="{x:Type igd:SummaryResultsPresenter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igd:SummaryResultsPresenter}"> <Grid> <ItemsControl x:Name="SummaryItems" Background="{TemplateBinding Background}" BorderBrush="{TemplateBinding BorderBrush}" ItemsSource="{TemplateBinding SummaryResults}" /> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style>
Thanks for your help, I was able to implement it the way I need it to be. However, there is a minor issue.
Please take a look at the attached screenshot. I need the SummaryResultPresenter's cell (in red box below) to have the same background as the groupByRow.
[image removed]
And here is the code snippet...
<Style TargetType="{x:Type igd:SummaryResultPresenter}"> <Setter Property="HorizontalAlignment" Value="Right" /> <Setter Property="Template"> <ControlTemplate TargetType="{x:Type igd:SummaryResultPresenter}" > <Border Background="{TemplateBinding Background}" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="1" Padding="{TemplateBinding Padding}" ToolTip="{Binding Path=SummaryResult.ToolTipResolved, RelativeSource={RelativeSource TemplatedParent}}"> <TextBlock HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" VerticalAlignment="{TemplateBinding VerticalContentAlignment}" Text="{Binding Path=SummaryResult.DisplayTextAsync, Mode=OneWay, RelativeSource={RelativeSource TemplatedParent}, Converter={StaticResource PrefixRemover}}" />
Just checking in, did you have any other questions or concerns on this matter?
Thank you for your response.
I believe this solution is viable and not really hacky. The Style that you see in the sample project that I sent you is the exact same default style for the GroupByRecordPresenter. The only difference is that a negative margin is added to the GroupBySummariesPresenter to move it up to the same row as the header. I have tried resizing columns and the window without any issues arising.
Regarding removal of the item count on the text that looks like (x items), I would recommend that you add an EventSetter to that style for GroupByRecordPresenter to handle the Loaded event on them. In the event handler, you can set the following code to remove the (x items) item count on the GroupByRecordPresenter:
GroupByRecordPresenter GRP = sender as GroupByRecordPresenter;GRP.Record.Description = ((GroupByRecord)GRP.Record).Value.ToString();
I hope this helps you. Please let me know if you have any other questions or concerns on this matter.
