I am using the xamDataChart control, and when I try to add a ScatterLineSeries to a SeriesCollection I get this error. I am using Infragistics 14.1 currently. Is this issue resolved in version 14.2 of the software? This is kinda a work stoppage for me.
Hi Ed,
Thank you for your reply. I created a case with number CAS-152854-Z7K5H0. Let’s continue our discussion on this matter in the case.
I have instances of my application working correctly with ScatterLine series, so an example is not required. I have an extremely complicated date set I am bound to, which uses all manner of ICustomTypeDescriptor enough to make your head swim. All of this is in production code, so I will have to make a sample project and extract allllll my code into it an open a ticket, because it's proprietary.
Thank you for your post. I have been looking into your issue and I cannot reproduce it on my side. I am attaching a sample application(DataChart_ScatterLineSeries_Sample.zip) that shows the behavior on my side. Could you please tell me what I am missing?
