1405
Custom XamDiagram Representation
I need a representation as attached. The below link fulfills half of my requirement.
http://help.infragistics.com/Help/Doc/WPF/2014.2/CLR4.0/html/xamDiagram_Binding_to_Hierarchical_Node_Data_with_References.html
My Implementation has below class structure:
public class Employee : INotifyPropertyChanged
private string _name;
public string Name { get { return _name; } set { _name = value; OnPropertyChanged("Name"); } }
private ObservableCollection<Employee> subordinates;
public ObservableCollection<Employee> Subordinates { get { return subordinates; } set { subordinates = value; } }
public event PropertyChangedEventHandler PropertyChanged;
protected void OnPropertyChanged(string propertyName) { if (PropertyChanged != null) PropertyChanged(this, new PropertyChangedEventArgs(propertyName)); }
I'm not able to make the lower portion of the image (nodes linked to each other from left to right). The representation should flow from Left to Right.
Can anyone please help me in this.
Note: I'm using XamDiagram 14.2. You can assume, that I'm able to add XamDiagram and playaround it.
