35
xamgrid row doesn't accept empty text
i have xamgrid with using 12.2 version dll below is the source code.  in any row if i try to enter empty value, its not accepting instead it will retain the old value. i found the below url. it doen't telling what i need to install. i do have product key with me. could you please help me out.
http://stackoverflow.com/questions/15755772/xamgrid-doesnt-allow-to-select-empty-text
<ig:XamGrid x:Name="XamMetaGrid"
            HorizontalAlignment="Left"
              Margin="5,52,0,42" PreviewTextInput="XamMetaGrid_PreviewTextInput" PreviewKeyDown="XamMetaGrid_OnPreviewKeyDown"
              ItemsSource="{Binding FillGrid, Mode=TwoWay}" IsEnabled="True" Width="601">
            <ig:XamGrid.Columns>
                <ig:UnboundColumn Key="EditColumn" HeaderText=" " Visibility ="{Binding ColumnVisibilityCustom.ColumnVisibility, Source={StaticResource proxy}}">
                    <ig:UnboundColumn.ItemTemplate>
                        <DataTemplate>
                            <StackPanel Orientation="Horizontal" >
                                <Button Content="Edit" Width="40" Click="EditButton_Click">
                                    <ig:Commanding.Command>
                                        <ig:XamGridRowCommandSource EventName="Click" AllowEventHandling="True" CommandType="Edit" >
                                        </ig:XamGridRowCommandSource>
                                    </ig:Commanding.Command>
                                </Button>
                            </StackPanel>
                        </DataTemplate>
                    </ig:UnboundColumn.ItemTemplate>
                </ig:UnboundColumn>
            </ig:XamGrid.Columns>
            <ig:XamGrid.SelectionSettings>
                <ig:SelectionSettings ColumnSelection="Single" RowSelection="Single" CellClickAction="SelectRow"  >
                </ig:SelectionSettings>
            </ig:XamGrid.SelectionSettings>
            <ig:XamGrid.EditingSettings>
                <ig:EditingSettings />
            </ig:XamGrid.EditingSettings>
            <ig:XamGrid.PagerSettings>
                <ig:PagerSettings AllowPaging="Bottom"
                            PageSize="100" />
            </ig:XamGrid.PagerSettings>
            <ig:XamGrid.ColumnTypeMappings>
                <ig:ColumnTypeMapping ColumnType="ig:TextColumn" DataType="system:DateTime" />
            </ig:XamGrid.ColumnTypeMappings>
        </ig:XamGrid>
  • 35319
    Suggested Answer
    Hello Ajay,
    I am checking if this is still an issue for you.
    If you require any further assistance please do not hesitate to ask.
  • 35319
    Hi Ajay,
    Thank you for your post. I have been looking into your concerns and I was wondering that is the underlying type of the property that presents your column?
